4x4 Error Issue
Aross88
Rhode Islans
New member here. I have a 94 EB with auto locking electronic 4x4. Like many other people here, 4x4 randomly stopped working. I read through many posts here and they're helping but I have a few issues I can't seem to find.
The shift motor works and will engage 4 Hi. 4 lo just clicks. The weird part is with the shift module under the kick plate. If I do the the self test, sometimes it blinks meaning no errors and sometimes it stays on for 30 secs. However, when i shut the truck off and turn it back on, the module doesn't work and therefore no 4x4. If I unplug the module and hit the test button, 4x4 works. I bought a "new" module and the same issue only this one blinks with no errors. But I still have to reset it to engage 4x4. The only thing I haven't replaced on the 4x4 line or tested is the speed sensor.
Any thoughts?
Yo
See 1356 Electric Shift Speed Sensor Wiring Diagram & TESTING"...The speed sensor is important because the vehicle must be stopped for a shift into or out of 4L. The shift module won't make the shift if the vehicle is moving. speed sensor should show 225-275 ohms with the vehicle stopped. Check at the module connection..." Miesk5 Note Ford Part Number is 7f293 speed sensor
Source: by Dustin S @ http://web.archive.org/web/20100923...rford.org/documents/electric1356/elec1356.htm
1994 Bronco Dealer Brochure by Ford via Dezo's Garage @ https://www.xr793.com/wp-content/uploads/2020/07/1994-Ford-Bronco.pdf
1994 Bronco Brochure, Partial; Cover & Page 3; plus pics of EDDIE BAUER model accessories.
by Ford via BigRob at 1994 Ford Bronco Bronco Accessories pictures, videos, and sounds | SuperMotors.net
➡ASAP, find out if speed control recall work, if equipped was completed @ Recalls Look-up by VIN (Vehicle Identification Number); or @ Welcome to Ford Owner | Official Ford Owner Site; or ... have VIN ready. While there, see most Ford dealer maintenance/repairs done @ any dealership nation-wide.
