265/75 R15 Goodyear Wrangle RT/S
redlight runner
Pennsylvania, USA
I run 265/75 R15 Goodyear Wrangle RT/S they fit perfect for me right to the wheel well edge, I don't like a tire that runs outside the well, but that's just me. I'm not sure that I couldn't get one size larger but again it probably would run out, you can never get the exact foot print from one manufacture to another so would one size larger put me out of the wheel well? Just a thought but its soon tire buying time.
You can look up the sizes of of other tire brands and models at tirereck.com to see what's still avail in our "dinosaur" sized 15" wheel; yep, less being made in various ODs/Widths for the 15" wheel.
You current 265/75 R15 is probably;
Section width = 10.5"
OD = 30.7"
If you go to a Wrangler MT/R with Kevlar in 32X11.5R15, the sidewalls will be still inside fenders, ever so slightly/
Section width = 11.4"
OD = 31.8"
or;
Yokohama GEOLANDAR ATII 32x11.50R15 Overall Diameter 31.8" Section Width 11.5 Set of 4: $508.00 @ Tire Rack + $90.00 shipping May 2010
Falken Wild Peak A/T Overall Diameter 31.5"; Section Width 11.6" $160.00 each @ discounttiredirect.com JULY 2010
Hankook DynaPro MT RT03 32x11.50R15 Overall Diameter 31.8" Section Width 10.8" $195.00 each by discounttiredirect. May 2010
Kumho Road Venture AT KL78 32x11.50R15 Overall Diameter 31.4" Section Width 11.4 on 9.0 Set of 4: $436.00 Tire Rack + $82.24 Shipping May 2010
Source: by kumhousa.com
Mastercraft (Cooper) Courser MT 32x11.50R15 Overall Diameter 31.4"; Section Width 11.4 on 9.0" wheel
Source: by mastercrafttires.com
A tire's section width (also called 'cross section width') is the measurement of the tire's width from its inner sidewall to its outer sidewall (excluding any protective ribs, decorations or raised letters) at the widest point. This measurement is made without any load placed upon the tire and after the tire has been properly mounted on its industry assigned measuring rim and has been inflated and reset to its test pressure after 24 hours.
Overall Diameter
A tire's overall diameter is the outer diameter of the tire measured in the center of the tread. This measurement is made without any load placed upon the tire and after the tire has been properly mounted on its industry assigned measuring rim and has been inflated and reset to its test pressure after 24 hours.
Also;
Tire Circumference Differences; "...ensure that the tires you decide on buying are not discontinued (not now manufactured by the tire maker). Ask around - don't rely on verbals by just one dealer. Because; A tire slasher messed my plans up $ wise in JAN when he slashed two 32x11.50 Daytons; they were just a year old at the time. I found that Dayton stopped making em (in 32s) right after I bought them and None are avail anywhere....; so I ended up w/ two Michelin LTX® M/S 32x11.50R15 in an emergency buy that late Saturday afternoon; guess what? right, they stopped mfg em too! Prob is finding tires in the future to replace the Daytons that have an actual inflated diameter close enuf (see below) to whatever is in in-place so that we can do the std rotation & don't rip up the Xfer case, etc. This is by BW for its Xfer cases, esp the 1356; Diameter & Pressure Difference for Transfer Case Operation; "...Before attempting any diagnostic work or trouble shooting on the transfer cases, make sure that the tire pressures and circumference are all the same. Do not just compare tire sidewall labels, you must measure each tire around the center of the tread. A stagger gauge will let you do this with the vehicle on the ground in 5 minutes. The tires must match in size to ¼” (.250) if they do not sell the customer on a new set of tires and again measure them again..." Source: by BW via Mike at rsgear.com If you want to buy on-line, after picking out the combo you need, go to a local privately-owned tire shop and see if they'll beat/match total installed cost w/free life-time rotations and anything else you can get (road hazard...etc.)
Source: by miesk5
What year? If 92-96 and got to a larger OD tire; you should recalibrate the PSOM; I have that info in my site @ http://www.broncolinks.com/index.php?index=430
eholt80
