250 six cylinder in 66 with 3 speed bellhousing
paulc396
I need to hookup a med 70s 250 six cylinder to my original 3 speed transmission any ideas on what bellhousing to use to make this work. my original is a 5 bolt and the new engine is a six bolt. Thanks for any help i can get.
Mavericks and comets had 250's in them. Maybe you might be able to get a bellhousing from one of them.
nedceifus
Hey man, how is the swap going? What are you using for a oil pan?
william.jones2
Northern Virginia
I would like to swap out my old 6 with a larger 250 as well. I am interested to hear/see how yours works out. I have a '67 with a 170 and a three on the tree that desperately needs more power. I think the larger I6 are the way to go. Good luck.
Bill
Jebus
I'm doing the same: 69 250 six w/ c4 auto in a 68 Bronco that has a 170 w/ three speed manual.
And yes, it uses a small block bellhousing. Keep in mind that for a manual on a 250 six, you have to use a six cylinder flywheel.
The good thing is that you can use a 250, 240 or a 300 flywheel. Best to get a complete bellpack from one of these.
And yes, you have to make an oil pan by "melding" a 170/200 rear sump pan to the 250 front sump pan.
IIRC ford never made a rear sump 250 pan.
...JJG
