1996 fuel pump wiring issues
96ford400
Florida
Hey, im Doc, I got a 1996 bronco with the 5.0. Bought cheap and already wrecked but wiring is a nightmare. The hanger assembly has 4 wires at the top but mine had only 2 connected with the float assembly grounded to the mounting ***** itself. What is connected to what on the pump. Took the tank home to clean...Pump had no power and wouldnt run. Inertia switch checked out.. Also needs a new return line to the pump also. What is the line size for the line going back to the pump not to the fuel filter? Just verifying. Much appreciated!
yo Doc,
Let's workout the wiring first.
Supply (pressure) lines are blue; return lines are gray.
Blue supply lines are 3/8"; gray return lines are 5/16".
I prefer NAPA LINES.
For much more Fuel System info, see http://www.supermotors.net/clubs/superford/registry/2742/12737-2
ASAP, find out if speed control recall work, if equipped was completed @ Recalls Look-up by VIN (Vehicle Identification Number) @ https://vinrcl.safercar.gov/vin/
To confirm current status, use this guide by jowens1126 @ https://www.fullsizebronco.com/threads/93-94-96-cruise-control-recalls-repair.457065/#post-6530073
Note that the 93 recall is different than the 94-96 recall.
Here's the 1996 Bronco/F-Series Workshop Manual partial @ http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ https://www.fleet.ford.com/parts-service/resources/owner-manuals/
96 Bronco Dealer Brochure @ https://www.supermotors.net/registry/3549/15947-2
... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ http://www.supermotors.net/registry/2742/80431-2
Register to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ Welcome to Ford Owner | Official Ford Owner Site .
96ford400
Florida
yo Doc,
ASAP, find out if speed control recall work, if equipped was completed @ Recalls Look-up by VIN (Vehicle Identification Number); or @ Welcome to Ford Owner | Official Ford Owner Site; or ... have VIN ready. While there, see most Ford dealer maintenance/repairs done @ any dealership nation-wide.
To confirm current status, use this guide by jowens1126 @ 93 & 94-96 Cruise Control Recalls Repair
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ Owner Manuals | fleet.ford.com
96 Bronco Dealer Brochure @ 1996 Ford Bronco Technical Info pictures, videos, and sounds | SuperMotors.net ... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ 1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
Much appreciated on the information... Im going to look through all of it after I get dinner situated. Nothing like some light reading!
YW!
I just edited my previous reply to include the urls because this pos site doesn't like copy and paste.
96ford400
Florida
YW!
Also, the tach isnt registering, where would I start? There are alot of ground issues from the wreck it was in. Im still repairing everything on the passenger side fender, it ripped a lot of the wiring out... Ignition cylinder was tampered with but before I fixed the fuel pump, it would turn over just not fire up.. Even the door chimes worked with the cobbled together wires.
Tachometer Inoperative, Gasoline Engine
Circuit.
Sensor.
GO to Pinpoint Test L. @ http://www.diesel-dave.com/vehic/manual/stj/stjd1017.htm#l
In connector:
Pin Number Circuit Circuit Function
1 904 (LG/R) Charge Indicator Lamp
2 932 (GY/W) High Beam Indicator Input
3 57 (BK) Ground
4 450 (DG/LG) Fasten Belt Indicator Input
5 29 (Y/W) Fuel Level Input (with Tachometer)
6 19 (LB/R) Instrument Cluster Illumination Input
7 57 (BK) Ground
8 2 (W/LB) Right Turn Input
9 648 (W/PK) Tachometer Input Signal
10 398 (BK/Y) Tachometer Ground (for 8 Cylinder)
11 784 (LB/BK) Low Range Indicator Input
12 210 (LB) 4x4 Indicator Input
13 640 (R/Y) Power Supply in RUN and START
14 16 (R/LG) Charge Indicator Input
msgsnprtom
