1986 bronco II Y/LB wire fuse?
Jbrownjr
Kuna, Idaho
Looking for where a fuse might have blown for a yellow wire with light blue stripe in the dash behind the cigarette lighter.
My son attached a USB charger using this wire and a ground alongside it but didn't tape the connectors. Removing it...I grounded it out. ("Zap", and now no juice)
I checked the fuses on the driver side kick panel, and all seem good. Now I'm wondering if this has a fusible link somewhere else?
This diagram seems to suggest it went to the ammeter? (https://www.therangerstation.com/tech_library/EDiagrams/files/diagram_charging_1983to1985_1.JPG)
Or maybe...it's actually for the original lighter. 🤔
Still, no representation of a fuse for the cigarette lighter either.
That would be really odd to run it that way, most likely it is just happen chance that it has the same wire color. I will see if I can find a diagram as well.
Actually have not found a diagram yet, but this diagram says it should be fuse 16?
frankhall2038
Back
