Keithkos92
- Joined
- Dec 9, 2019
- Messages
- 13
- Reaction score
- 0
My wipers will not work at all what all should I check first? Are these well know for this problem
Nice Bronco! With the wiper issues, did you check the fuse box for a blown fuss?
The fuse box lid was missing and im having a hard time finding a diagram that looks similar
This is what I can find didn’t see anything about wipers
I don’t hear a thing I will try that here in a moment and report back
Thanks for your input I’ll report back once I’ve tried everythingIf that doesn't work, you could remove the motor and rebuild it, or of course get a new/used one. I'd look for one in a junk yard for cheap and replace it to see if that works.
Wiring Diagram with Governor in an 83 Source: by Seabronc (Rosie, Fred W) at Ford Bronco Zone Forums |
Wiring Diagram without Governor in an 83 Source: by Seabronc (Rosie, Fred W) at Ford Bronco Zone Forums Now they are gone. HoweverInretrieved each via web archive |
Just had a thought...
I had an issue where the fuse didn't blow but it corroded and killed power that way. If you have older fuses it might be worth replacing them.
Thank you sir will be looking into this after I fix my driveshaft ujoint had enough this morningYo Keith,
The ws wipers are fed through ignition Switch as shown in wiring diagrams I posted above. Ignition switch Power come from a fusible link attached to starter relay.
