Interchangeable seats??
C
CLC
Guest
I own a 1991 Bronco and am in need of new seats. I found some bad**s seats on LMC truck parts but they're listed as a fit only to '80 - '86 models. I was wondering if it was possible to still install the seats and simply have to drill new holes or if I would run into totally separate issues. Thanks!! (below are the seats I'm looking at)section-image-5da8076b979dd0.94591294-1x.png
Yo CLC,
WELCOME!
"...All '80-96 Bronco & '80-97 F-series seats (bench, bucket, whatever) are interchangeable. The most you'd have to do is add wiring for the lumbar pump. The floorpans are identical where the front seats go...."
Source: by Steve83
So they should fit because the floor pan bolt pattern is same.
see my bucket seat section in my recovered site @ https://web.archive.org/web/20101224175040/http://www.broncolinks.com/index.php?index=312
to see supermotors LINKS remove to first http addy and it'll take you to original site
for example in above url remove https://web.archive.org/web/20101224175040/
And bang on http://www.broncolinks.com/index.php?index=312
see attached
gl!
ragtop69
Lincoln, CA
Have you tried a JY on line? I can recommend Rancho Ford Trucks in Rancho Cordova, CA. They even have FSB seats on occasion. I got a driver's side captain's chair out of an EB Bronco from them for my '95 XLT for something like $100.
Rickyb571
