Bumper
KansasBronco
Kansas
i cant seem to find any bumpers out there that can hold a winch. does any one know of anyone that can make one or makes them? i dont have the time or the welder to do it. thank you!
Jeff's Bronco Graveyard has some new bumpers, including those for a winch, with or without a brushguard. I'm thinknig of building my own out of 3/16" plate, since most I've seen have 1/8" plate. If you have one made, post your design, JSM84
You can check out Warm Industries. Along with hubs and winches, they sell bumpers. One that come to mind is the "Enforcer", looks great and sells for under $500. But i think it's 1/8" thick at best, and will get bent if hit while offroading. I have a friend that built his own winch bumper out of 5" pipe, have some pics at superford.org under "Long's Ranch". I can post one pic if you want an idea. JSM84
13MWZ
Pickup Man
Afghanistan
I put a Warn bumper on my pick up. I like the looks but otherwise I'm pretty dissapointed in it. The center section is solid enough for the winch but the outer parts are flimsy as could be. I think the stock bumper is stronger than the 'ears' of the Warn. Also, the panels that cover the gaps on top dont follow the lines of the truck worth a darn. Here's a picture of it, there should be some more in the gallery
Justbust1n
walkertown
Made this one my self it is 6x2x1/4 inch on the base and 1 1/2 x 1 1/2 x3/16 around the front and fog lights and it has some 1/8 inch diamond plate on the top followed by some C bar that is also 1/4 imch think and yes it is heavy!!! with a 12500lbs warn winch takes out any tree you want , and on some long drinkin nights it happend upon some some stop signs and i think i got a no passing one time with out a scratch , well there might have been a scratch but NO DENT... hahaha , i made it alot more durable cause i didnt feel like buying one for 800.00 dollars and then denting it up, so i made this one last for a while
Justbust1n
walkertown
what size winch is that on yours??
1fast
im gonna make a couple to put on my truck and fora few buddies if you are close to nc id be glad to do do one for cheap
you paint i just weld it ill post pics when i get mine done
Not my rig, it's a friend I wheel with, but that's a Warn 12,000 lb electric winch. It gets used quite often to pull other rigs out of trouble, but I wouldn't put anything smaller on a fullsize Bronco with 40" tires.
eholt80
