'66 six cylinder accelerator cable
brendon
anybody out there know where i can find an accelerator cable for a '66 six cylinder bronco? i've checked out
the usual parts sites and done alot of searching on the web. i would also like to find a drawing of the correct
position of the cable even if it is hand drawn!!! i've looked at old mustang and falcon setups, but they all have mechanical (hard) linkages. the cable that is on my bronco now is to short to lay in the bracket that secures it in place.
SAYBYE
Hi have you tried looking for an Econoline cable? just a thought
SAYBYE
Hi Try www.blueovaltruckparts.com I don't have a site for Obsolet Ford parts. Here is an old ad that I have maybe he can help. Wanted 1966-1977 Ford Broncos call Mike Noth Pekin,IL 309-256-9810 Post if you find one I'll keep looking
SAYBYE
Try www.macsautoparts.com they have a 20" cable or www.lmctruck.com they have cables for newer Broncos. Give them a call they might be able to hook you up
Also you can check the cable on a six cylinder Maverick or Comet. They are pretty long.
kal
cali
anybody out there know where i can find an accelerator cable for a '66 six cylinder bronco? i've checked outthe usual parts sites and done alot of searching on the web. i would also like to find a drawing of the correct
You can find the cable at Obsolete Parts Company out of Nashville, GA. The original for part number is 9A758. I just ordered one yesterday. http://www.parts123.com/parts123/yb.dll?parta~partsort
Check out this schematic for the placement. http://broncograveyard.com/dia/6/engdiagaspedal6cyl.jpg
kal
kal
cali
Thanks for the suggestion. The specific part number I believe is C5TZ-9A758-AH for the 20 inch Ford accelerator cable. This was used across many Ford trucks. Problem is noone can find it! ugh.
kal
cali
Apparantly about a year ago someone unearthed a huge quantity of original Ford 20 inch C5TZ-9A758-AH accelerator cables. Everyone from Dennis Carpenter to every other old ford parts guy listed the part. They all seem to be out now. I did see one on ebay but it was used and looks to be in pretty poor shape. ugh. thanks for the tip.
kal
cali
Wild Horses out of Stockton CA located one that would work. Thanks Guys!
Similar threads
eholt80
